Can use sound dampening foam.
What case do you have?
What is the source of noise?
Also, undervolt case fans + cpu fan's, turn down the fan speed on GPU etc with msi afterburner or some other program.
Use drivespeed for DVD drives to limit there speed when they are reading which reduces noise etc.
You trade temperatures for silence.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/66227-sound-dampening/#findComment-905288
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/66227-sound-dampening/#findComment-905326
You can do lots of things: Use rubber screws/washers, play around with fan speeds (Undervolt fans, turn down RPM of fans), use sound damping foam.
CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3
GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+
https://linustechtips.com/topic/66227-sound-dampening/#findComment-905349
Put the PC outside and get some really long cables ^^
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/66227-sound-dampening/#findComment-905377
