Download speed issues...
By
lilwic
in Networking
in Networking
Solved by ModerateSkill,
Are you sure you're not getting confused with MB/s and Mb/s? (Sorry for being condescending if you know). Steam displays download speed in MB/s and it's likely that your xbox displays it in Mb/s. The difference is that a Mb is an 1/8th of the size of a MB. This means that the 2MB/s you see in steam, is the same as 16Mb/s that you're likely seeing on your xbox.
PopsicleHustler ·
Posted in Audio1 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
