So I've got an HP Spectre x360. Great laptop for doing school work, but I would like to know if using an external gpu on it is possible without opening it up. If I do, can someone tell me a laptop that has a decent cpu and that I won't have to open up to use an e-gpu? (And yes I know about the razer core, but I'm not will to shell out $500 just yet)
Thanks
https://linustechtips.com/topic/661844-egpu-setup-help/
500$ is the cheapest eGPU hub available. And it doesn't work with 99% of laptops. Currently - eGPU sucks big time. Just get a laptop with a 970M
https://linustechtips.com/topic/661844-egpu-setup-help/#findComment-8555264
There are graphics adapters that work over USB, but generally those are pretty crap and should be only used in a last resort for plugging into projectors. They're meant for presentations and light work rather than gaming.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/661844-egpu-setup-help/#findComment-8555265
GPUs don't boot with those. Nvidia drivers require a minimum of PCIe 3.0 x4 to work properly IIRC
https://linustechtips.com/topic/661844-egpu-setup-help/#findComment-8555274
I was talking about these things: http://www.ncix.com/detail/startech-com-usb-3-0-to-vga-fa-95748.html . Has nothing to do with Nvidia.
https://linustechtips.com/topic/661844-egpu-setup-help/#findComment-8556112
  • 3 weeks later...
On 9/16/2016 at 1:47 PM, planecar457 said:
Giant pain in the ass not worth the effort
what's your end goal here? why not just get a cheap gaming PC?
https://linustechtips.com/topic/661844-egpu-setup-help/#findComment-8638626
