so i'm looking to buy wireless earbuds
requirements(i have no set budget)
1:battery life must be 8 hours or more
2: volume control w/ mic not required but recomended
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
https://linustechtips.com/topic/661824-wireless-earbuds/
Airpods
/s
good wireless earbuds do sadly not exist , stay wired and save yourself the trouble , only good wireless solutions are headphones
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/661824-wireless-earbuds/#findComment-8555108
Just now, M.Yurizaki said:
Your best bet are sports earbuds or collar earbuds. Anything in the $100 range should get you want you want.
any suggestions
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
https://linustechtips.com/topic/661824-wireless-earbuds/#findComment-8555119
Just now, crysilis said:
any suggestions
Eh, they probably perform the same, so it's a matter of preference.
If you're looking for something cheaper, Anker has some for about $30 USD and supposedly lasts for 8 hours. I have them, they're okay, but they kind of don't like to settle in the ear comfortably.
https://linustechtips.com/topic/661824-wireless-earbuds/#findComment-8555126
5 minutes ago, Space Reptile said:
Airpods
/s
  Reveal hidden contents
2 minutes ago, crysilis said:
any suggestions
Jasyabird X2s, Plantronics BackBeat Go2's, and Jaybird Freedoms are decent. The freedoms are just stupidly priced at $200, but they're actually comfortable and normally sized, and the plantronics just have sub par battery life (4~ hours), but the version 3 probably has better battery life.
Edited by djdwosk97
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/661824-wireless-earbuds/#findComment-8555128
The Jaybird X2 are probably your best bet, I've heard very good things about them, and are pretty compact.
I personally use the Sony AS800BT, which are decent as well, but the controls are just a tad fiddly, because the button doesn't click much. They also only last up to about 5 hours. The newer versions, the AS600BT gets 8hrs, but they're a bit bulky.
https://linustechtips.com/topic/661824-wireless-earbuds/#findComment-8556521
