A 1440p monitor between 400-500
Here is a great deal on the ASUS PB277Q 27" 1ms (GTG) TN Panel Widescreen LCD/LED Monitor, Height, Tilt, Pivot and Swivel Adjustment, Built-in Speakers, Extensive Connectivity with Native WQHD Content , http://www.newegg.com/Product/Product.aspx?Item=24-236-721
I found.
Has a 75Hz refresh rate which I'm sure the 1070 is capable of. Goes for about $340 so it's actually less than you're budget and you'll save money. It is a TN Panel so if the quality of content is what you're looking for there is an IPS model for about $10 more but it does have a 144Hz refresh rate but a 5ms response time.
The ASUS PB Series PB278Q 27" 5ms (GTG) WQHD HDMI Widescreen LED Monitor 300 cd/m2 80,000,000:1 Built-in Speakers, Height & Pivot Adjustable , http://www.newegg.com/Product/Product.aspx?Item=24-236-294
