My previous thread died, so I'm reposting this:
a while back, I decided that my CPU temps weren't good enough, and decided to remount my CPU cooler (212 EVO). Just for shits and giggles, I decided to take out my CPU, and marvel at how such a small component can use up so much power, and do so many calculations. when I turned by computer back on, I found myself in a boot loop. as it turns out, my PC wont boot up with more than one stick of RAM in each color on the motherboard. I have a dual-channel motherboard (4 DIMM slots total), and I'm currently running my RAM in slots 3 and 4, which as far as I understand, is the wrong way to run them. (reduces the ram to single-channel speeds, right?)
I don't have another LGA 1150 Motherboard handy to test what's wrong. Is it my CPU memory controller? My motherboard?
NOTE: all RAM DIMMS and RAM slots are confirmed working.
To clarify: both channels work, but each channel only accepts one DIMM without boot-looping
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/661418-how-do-i-troubleshoot-this-problem/
then only install one ram first to see whats wrong
Clear Cmos?
I'm not entirely sure, but that would be my first step
If your motherboard has dual BIOS try the other one.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
It works with one DIMM, and I'm using my computer with one stick in each channel. (one DIMM in the gray and one in the black)
it works with one RAM stick
1 minute ago, The Flying Sloth said:
Clear Cmos?
Been there, Done that. Didn't work.
the only conclusion I can come to is that i would need another LGA 1150 motherboard to test my problem, and see if the CPU's memory controller is broken, or if the motherboard is broken.
Laptop:
Did you touch the pins when you pilled put the CPU, you may have marginally bent one which could cause this issue. Your motherboard should be fine as you haven't done anything stupid to it.
I would hazard a guess it is the socket itself, check it for obstructions or conductive materials.
@rice guru
I thought that this was the issue, so I checked my motherboard for any bent pins, and didn't find anything. I looked at the pins straight on, and they all seemed to line up, so I assume my socket pins are fine. I just honestly don't know what to do at this point other than get a new motherboard
Laptop:
Would vacuuming the socket be ok? Im about to clean my pc out and im wondering if its fine to just stick a vacuum in the case
HELL NO, HELL NO, HELL NO. Get a can with compressed air instead
I'm part of the "Help a noob foundation"
If you have a spare drive, just reinstall the OS as a test to see if its truly a hardware issue. And or if you have a second computer download MemTest86 ISO, and run it with all ram sticks in to see if you have bad RAM.
Core i7 3770K @ 4.1Ghz (stock voltages) H100i, 32gig of RAM (9-9-9-24), 500gig Samsung EVO 850, 6 Monitors. GTX980ti, R9 380
Do you have any friends with 1150 mobos that you could test with? if not send a support question to the manufacturer.
Well, if you have knowledge of how DC motors work you would know that when supplied with a DC current the fan spins, if spun by hand, you get a DC current SO as long as you would like to send current the wrong way through your motherboard, introduce copious amounts of static electricity, risk spinning your fans above recommended RPM I wouldn't BUT you can always try if you'd like
(P.S. make your own thread next time instead of hijacking)
I think we've all thought of doing this at some point
@rice guru
Canned air is a massive ripoff, just use a compressor.
@rice guru
