hello LTT forum, i have this pc parts
Motherboard : ASUS H81M-K
Graphic Cards : GeFroce GT 620
RAM : SAMSUNG PC3-12800 8GB (2x4GB) 11-11-11-28
CPU : i7-4790K 4.0 Ghz
HDD : ST1000DM003-1ER162 1TB , ST3500312CS 500GB
PSU : Thermaltake Litepower LT-700P 700W  Black Edition
Case : SMC5825
according to my post, i will get a new psu ; rm650x or rm650i (which one is better?) and ups too
i wanna get aio gtx 1080 or gtx 1070 (brand suggestion?) and cpu liquid cooler (suggestion?)
will it fit in my case ? thanks
https://linustechtips.com/topic/661111-will-it-fit/
i dare you to buy a 4790k and a H81 motherboard. Get an Z97 pls.
Also that case is shit and will probably not be able to hold an AIO.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8547385
well sorry for my stupidity , back then i dont care that much abt pc :(
so should i get a new case ? i cant replace the mobo right now
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8547449
Not really a point for AIO graphics cards. I have a MSI version of the GTX 1070 and it runs nice and cool under load.. and yeah switch out the case and motherboard. Can't expect to fit anything inside your case, looks like the low end computers you would buy at bestbuy.
• OS: Windows 10/10 Pro  • SSD: Samsung 256GB 850 Evo Series *  • HDD: Seagate 1TB  • GPU: MSI GeForce GTX 1070 GAMING X (SLI)
• CPU: i7-4790K OC 4.7GHz Quad-Core Processor • Case: NZXT H440 (Black/Red) • PSU: EVGA SuperNOVA NEX 650W
• RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory • Mobo: MSI Gaming 5
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8547468
so aio graphic cards is not all that good ? and what motherboard and case do you suggest ?
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8547498
Why get a new cpu cooler?
Your current psu is fine and you don't need a new one.
You should probably get a new case though to better cooler the new graphics card.
Moved to New Builds and Planning.
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8548528
when i was listing my part, someone worried about my psu being bad grades so i consider buying a better one
tho idk if i need to change the case, i want to get gtx 1080 or gtx 1070 aio or non aio , i would rather not to get the aio gpu if i need to change my case, i dont have cpu cooler and considering getting one , but do i need to get it ?
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8550782
It'd be a good idea to change your case to better cool a 1070 or 1080 whether it uses an AIO or not. A blower cooler might be fine without a new case.
You don't need a new cooler unless your current temps are too high.
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8551180
alright, i will see what will happen first then deciding on the case later
thanks for the feedback LTT
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8552317
Depending on what color your build is. I'm loving my h440 and msi gaming 5 combo
https://linustechtips.com/topic/661111-will-it-fit/#findComment-8554553
