so i just needed to know how many radiators you would need im cooling my cpu and gpu
this was the radiator i was looking at but just need some opinions on whether that is enough for cpu and gpu?
http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_297_1270&products_id=18730
https://linustechtips.com/topic/66035-radiator-help/
120mm for each part. Double it for more headroom so (120mm x2) x2. The 360mm should be fine though.
https://linustechtips.com/topic/66035-radiator-help/#findComment-902318
@WoodenMarker is correct, but if you want to overclock, as I'm sure you do if you're spending money on a custom loop, then perhaps a 360 and try to stick a 240 somewhere if you can, then you can go balls out on 1.5v
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/66035-radiator-help/#findComment-902330
alright thanks i might get another 240 rad , if i go with the two rads how do u think i should set it up in as in the fans so i can still have positive air pressure in my case ?
https://linustechtips.com/topic/66035-radiator-help/#findComment-902978
Would help to know which case you have. But if you want a general answer, stick more intake fans than outtake fans...
https://linustechtips.com/topic/66035-radiator-help/#findComment-903011
