-(16GB G.Skill DDR4 PC4-19200 2400MHz Ripjaws V for Intel Z170/X99 CL15 Dual Channel kit (2x8GB) 1.20V) X2
-Corsair Air Series AF120 LED Quiet Edition High Airflow Fan Twin Pack CO-9050016-RLED (Red)
-Gigabyte LGA1151 Intel Z170 ATX DDR4 Motherboards GA-Z170X-Gaming 3
-Seagate Barracuda 1 TB HDD SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
-Intel Boxed Core I5-6600K 3.50 GHz, 6 M Processor Cache 6 for LGA 1151 (BX80662I56600K)
-Corsair Memory CC-9011081-WW Corsair Carbide Clear 400C Compact Mid-Tower Case, Black Or
Phanteks PH-ES215P_SRD Enthoo Evolv Mini iTX Tower Window Case, Red
-EVGA SuperNOVA 750 G1, 80+ GOLD 750W, Fully Modular, 10 Year Warranty, Includes FREE Power On Self Tester Power Supply 120-G1-0750-XR
-Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2)
-Corsair Force LS Series 480 GB 2.5-Inch SSD CSSD-F480GBLSB
-Gigabyte GeForce GTX 1070 G1 Gaming Video/Graphics Cards GV-N1070G1 GAMING-8GD
My purpose is gaming and editing
Should i go with i7-6700k or i5-6600k is good enough?
Should i go with 64 ram or 32 ram is good for my purpose?
Is my power supply good?
Should i go with Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler CW-9060025-WW, Black or Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan (RR-212E-20PK-R2) is good enough?
I want a black and red build
Edited by Razzz
https://linustechtips.com/topic/659572-build-question/
13 minutes ago, Thread212 said:
Wtf?? 32 Gb is more than enough for editing..i mean u are trying to do some heavy rendering right?
For both gaming and editing buy the 6700k..
Buy the 2x16gb ram kit.
But it really depends on what type of editing he's doing, if it depends on cuda cores, a titan x or 980ti would take precedence over the cpu, if it runs better with more cores, a 5820k would give you more bang for the buck
https://linustechtips.com/topic/659572-build-question/#findComment-8530920
