Ok say i have a total of 8 PWM fans that i want to have speed down when they are not needed and speed up when they are, anybody know any fan controller or something to acheive this?
Intel 3930K @ 4,4ghz | Asus Rampage IV Extreme | Corsair Dominator GT 16gb | EVGA GTX 680 Classified | Asus Xonar Xense | Corsair HX 1050 | Corsair H100i | Corsair Force 3 120gb | Western Digital 2tb Black |
https://linustechtips.com/topic/65953-automatic-fan-control-with-4-pin/
Get 2, 4 way fan splitters, which are powered by molex and plugged into a PWM slot on motherboard (need 2, 4pin slots on MB)
If your motherboard has a way to control them that is....
Or use what tristan1035 said, fan xpert should be able to do it.
http://www.frozencpu.com/products/14982/cab-627/EK_4-Pin_PWM_4-Way_Splitter_Cable_-_Sleeved_Black_Black.html
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
Fan Xpert does that I think.
Yeah, my motherboard has Fan Xpert 1 and i have automatic fan control enabled, but they don't seem to go down at anytime so i donno if the software is bad or something.
Yeah that actually exactly what i have, and i have them set to go down when the cpu is at a low temperature and go up when it increases, but they dont seem to respond much...
You could use speedfan to control them. I'd suggest to check how you have set fan controlling in BIOS. My mobo is very specific how BIOS and software controlling work together.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Thanks i'll check that out when i get home from class..
