Looking for a case with glass panels
1 minute ago, EpicNinjaCheese said:Hi LTT forums!
It's around that time i need a new case because i am planning on switching to a water-cooled solution for my CPU and my Graphite 320T just doesn't fit the bill, fans being mounted outside the case to fit the rad and all :\
I'm after a case with tempered glass panels and a minimalistic design. I really like the "In Win 805 Infinity RGB" as it looks sleek and will go well with my glass desk but i have looked at a few reviews that all seem to say that airflow is a big no-no in this case, damn.
I really like the layout of the 600c, mainly because it has that panel which opens up on the top of the case to reveal a couple 5.25 inch bays. I also think the inverted layout is weird but i shall not care if the case looks fine.
I do (rarely) use my disk tray and i have a fan controller which mounts in one of those bays as well. I can do without both of these though if needed.
In the future i plan on doing a full custom CPU + GPU loop so if possible support for two radiators is awesome.
Also i am after an ATX form factor case, don't really mind large cases as i have a lot of room.
I have a 1200W Corsair power supply and a 980ti G1, 3 of the larger HDD's and an SSD, i can swap out a HDD for an SSD if the space is needed, not really worried about money on this one.
Thanks for all your help (in advance ofc)
If you are handy with a Dremel you can put a glass pannel on most cases. I did it with my define r5.
But http://www.phanteks.com/Enthoo-Evolv-ATX-TemperedGlass.html
