So I am building a ATX system for a client and he wants the smallest ATX case as possible, max 170 USD.
It needs to be ATX because he wants to SLI and he wants a mimo wifi card and maybe a PCIe SSD.
He wants a window.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/658656-smallest-atx-case/
there are mATX boards that support all you are requesting...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8517884
yes, but not cases. The GPUs will use 4 slots atleast depending on what model he wants and the wifi card is one slot and then if he wants a PCIe ssd then you are 100% out of slots no matter what mATX case you get, so ATX is kinda a need.
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8517910
Well your going to want cable management options then as you are cramming alot of hardware in this from the sounds of it. Should look at something like the Fractal Design R5.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8517937
well I have that one on the list, but he would like a bit smaller case
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8517956
http://pcpartpicker.com/product/6zV48d/lian-li-case-pca05fnb
Another option
Community Standards
"Beast Mode"
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8517991
9 minutes ago, legacy99 said:
yeah that would be perfect, if it had a window.
I really appreciate you replying :)
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8518030
A bit off the beaten path, but here it comes: Inter-tech AP-1. All aluminium construction with tempered glass side panels.
http://www.inter-tech.de/index.php?option=com_content&view=article&id=1118%3Aap-1-aluminium&catid=75%3Amittelklasse-gehaeuse&Itemid=922&lang=en
There are more things in heaven and earth then are dreamt of in your philosophy.
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8536705
8 hours ago, Infin8 said:
The Riotoro CR1080 and the Caselabs Bullet are also small cases. Does it need to be a Full-pcie-ssd? There are plenty of mATX boards with hyper m.2 on board.
he is already going to use the m.2 and that case already has problems fitting one none ref card in it.
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8538947
Cooler Master HAF XB EVO.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8539024
23 minutes ago, xgn said:
Jonsbo w2  german quality
yes, that is a nice case, might go with that, if he likes it.
sorry, but that is just ugly, there is no way he wants that, but thanks for the suggestion :)
https://linustechtips.com/topic/658656-smallest-atx-case/#findComment-8539160
