I run a pretty decent rig in my home setup, a 6600k with nzxt kraken liquid cooling and 16gb of ram, but my graphics card which I love the performance of seems to run hot. I personally don't know what it can handle and don't want to test it, but after playing games like borderlands the pre sequel and overwatch for about 2 hours it gets to 150 degrees Fahrenheit. And then it just sort of hovers there. So I was just wondering if that is a ok temperature or if I need to pump the fans faster (which they already spin quite loud)
The card is powercolor encased in a s340 - not overclocked
https://linustechtips.com/topic/658381-average-gpu-temps/
that's a great temperature for a card at full tilt
just a little FYI, we use Celsius for measuring CPU and GPU temperature.
anything below 80c is great, so you're fine
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/658381-average-gpu-temps/#findComment-8513927
We generally refer to temps in Celsius. 150f is ~65c which isn't that high at all for most graphics cards.
https://linustechtips.com/topic/658381-average-gpu-temps/#findComment-8513929
2 minutes ago, dexxterlab97 said:
Only 65 degree Celcius. God damn it Americans (no offense)
You are fine
It occurred to me after I posted it, thank you for future reference
https://linustechtips.com/topic/658381-average-gpu-temps/#findComment-8513952
