Double sided tape for SSD?
Solved by AlexMc,
If you have an appropriate place to stick it then double sided tape or Velcro should work. I'd probably go with Velcro as it would be easier to remove and replace the drive if necessary. Also SSDs weight very little, so a couple of strips should hold it in place easily.
Featured Topics
INotPablo ·
Posted in CPUs, Motherboards, and Memory4 -
Marie Rose ·
Posted in Cases and Mods2 -
4
HayLo995 ·
Posted in Storage Devices2 -
8
Mortal_2077 ·
Posted in Displays2 -
Brexy9 ·
Posted in Power Supplies2 -
Brexy9 ·
Posted in Graphics Cards1 -
1
