1 minute ago, BDMGuy said:
I'm going to put some new thermal compound on my computer and I was wondering what technique would be best.
The most popular would be to put a rice gain sized drop in the middle and putting the cooler on or the line method for large CPU's like the LGA 2011 types.
^Basically what I do.
It doesn't really matter as long as you use the right amount and it's centered on the cpu.
