Hello guys, i have many questions y doubts, first i have this desktop:
Intel 3rd Generation Ivy Bridge i5-3330 Quad Core Processor 3.0GHz/Max Turbo Frequency 3.2GHz
8GB DDR3 1600MHz RAM
1TB SATA 7200rpm Hard Drive
DVD+/-RW Dual Layer DVD Burner
Intel HD Graphics 2500 with one VGA and one HDMI Ports (support dual monitor output)
Integrated High-Definition Audio
Integrated 6-in-1 Media Card Reader
Integrated 10/100/1000 Gigabit Ethernet LAN Network Card
Genuine Windows 8® 64-bit Standard Edition
6 USB 2.0 Ports (2 front, 4 back); 1 PCI-e 2.0 x16 slot; 3 PCI-e 2.0 x1 slots
i want to know if i can run this GTX without problems:
Mfr Part Number: GTX650TIB-DC2OC-2GD5
Chipset: NVIDIA GeForce GTX 650 Ti Boost
Core Clock: 1020 MHz
Boost Clock 1085 MHz
Video Memory: 2GB GDDR5
Memory Clock: 6008 MHz (1502 MHz GDDR5 )
Memory Interface: 192-bit
Bus: PCI-Express 3.0 x16
CUDA Cores: 768
RAMDAC: 400 MHz
Max. Resolution: 2560 x 1600
Connectors: DVI-I, DVI-D, HDMI, DisplayPort
Thermal: Fansink (Dual Fans)
Dimensions: 10.2 x 5.2 x 1.5 inch / 25.90 x 13.20 x 3.81 cm
This Video Card Supports:
Microsoft Windows 8
NVIDIA PhysX Technology
NVIDIA GPU Boost Technology
NVIDIA 3D Vision Surround Ready
NVIDIA Adaptive V-Sync Technology
NVIDIA SLI Ready
HDCP - High-bandwidth Digital Content Protection
Microsoft DirectX 11.1
then the motheboard model it is a:
Have one to sell? Sell it yourself
Lenovo CIH61MI v1.1 H61H2-LM3 Socket 1155 Motherboard
Do this support up to 16 GB Ram?
Thanks in advance
https://linustechtips.com/topic/65718-many-questions/
Probably supports 16GB but 8 is more  than enough.
I'd get a 7850 (or 7870 if you can find one similarly priced) instead of the 650 Ti though, better performance for the same price.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/65718-many-questions/#findComment-897931
Whoa either I'm blind and don't see a mention of psu in the OP and people are just telling him to get cards without knowing what he has?!?!?!
Scary times in LTT.
Yes your computer can run a 650ti boost but please look for a 7850 as it is faster and same price. Also YOU HAVE TO MAKE SURE that your power supply has the connectors you need for the card and has enough watts/amps/volts. Most stock power supplies will have enough power these days but you have to double check. You will want 300+ watts and atleast 20amps in total for your 12v rails.
https://linustechtips.com/topic/65718-many-questions/#findComment-898001
hehe thanks guys yes i was thinking in get a 7850, ill get it by tomorrow, and i have a good power supply 750W 120MM Fan Silent Atx 12V rails. Thanks again guys
Wait just a damn minute!!
What "750W ATX 12v" power supply is this?? What you said gives ZERO information about the power supply.
About 90% of all power supplies are ATX, all must have at least one +12V rail, majority of power supplies use 120mm or 140mm cooling fans...and...
Do you have a low quality, over rated, Chinese sweatshop 750W...or something reliable like a Corsair HX750 750W...or even like a Seasonic made 750W??
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/65718-many-questions/#findComment-898064
