Hello. I'm Sam Callanta or samca.
Project kurosai will be a featured pc mod for Pangasinan Cyber Expo which will be held on November 25-26, 2016 at Robinsons Place Pangasinan.
Project kurosai means black - rhino (literally).
The color theme will be red and black. It was inspired from wintercorft's rhino. Kurosai will have a mix of oriental and robotic design.
The materials will be used are: bottom part of a case, 3mm and 4.5mm acrylic sheets and metal sheets.
Specs (to be updated)
procie: i5 6500
mobo: Asus maximus viii impact
ram: gskill tridentz ddr4 8gb
psu: Seasonic G series 650w
cooling: modded ek predator and barrow parts
hdd: 1tb wd
ssd:
avexir S100 240gb
The sponsored products will be exposed and highlighted during the Pangasinan cyber expo and future events.
14232454_1552296128130009_89148666569472
DRAFT
14212133_1552296761463279_14932173440489
MOBO:
14242334_1552296281463327_33991490421831
14257628_1552296518129970_30815366380394
RAM:
14258171_1552296201463335_88999264245518
14206008_1552296188130003_36087572125690
PCIE RISER
14196058_1552322668127355_78062906045941
So before I'll cut some acrylic and metal sheets I made a mock model of the mod.
But I will be using the bottom part of a case which i modified into a slanted position.
14207646_1552296328129989_62682326432426
Test fit.
14207872_1552296551463300_25979835374153
14264821_1552296674796621_19606054256865
14231234_1552296748129947_27959297655214
14231140_1552296718129950_42226679873473
https://linustechtips.com/topic/656285-project-kurosai/
21 minutes ago, saamwee said:
I'm not sure yet, This is still a work in progress
Haha, I meant your experience with PC's. Like do you work for a company? Do you have a YouTube channel? Or are you just a PC enthusiast? I am practically asking why should these companies sponsor your build?
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/656285-project-kurosai/#findComment-8481102
I do it for part time and  passion  xD my sponsor is not a company but a rich man lol, he saw my potential and gave me a hand.
I think companies should start to sponsor my build because I have a unique style in modding :)
https://linustechtips.com/topic/656285-project-kurosai/#findComment-8481257
Love this look of this already.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/656285-project-kurosai/#findComment-8486758
  • 1 month later...
  • 2 months later...
