Should be absolutely fine for format -
it is Defragmenting the SSD that is the big No No...
My Current Rig
CPU: AMD FX-8320 3.5GHz 8-Core Processor (OC 4.8 GHz) CPU Cooler: NZXT Kraken X61 106.1 CFM liquid CPU Cooler
Motherboard: Asus S-abertooth 990FX R2.0 ATX AM3+ Graphics Card: GeForce GTX 750 TI (OC)
RAM: Kingston HyperX Fury Black 16GB (2 x 8GB) & Kingston HyperX Fury Blue 16GB (2 x 8GB) DDR3 1866
PSU: Fractal Design Edison M750W 8O+ Gold Certified Semi-Modular ATX Power Supply OS: Microsoft Windows 10 Pro OEM 64-bit
Case: Fractal Design Core Blackout Edition ATX Mid Tower Case
reorganizes the file structure on the HDD so that fragments of files aren't scattered all over the place.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Just now, pikameow2 said:
I dont defrag my SSD what does defragging do anyway?
It makes many writes on your SSD which destroys the lifespan of the device.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
Sometimes defrag is turned on by default by windows. When you install a new SSD make sure defrag is disabled.
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
Especially on windows 7
My Current Rig
Windows 8, 8.1 and 10 can identify, if the device is a SSD or HDD and therefor either optimizing or defragmenting, respectively. Older ones will require some configuration indeed.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
