I almost never turn my PC off... The only time I do turn it off is when the following occur: Windows needs to restart for some reason, or a BSOD, and not turning my PC off seems to possibly be taking a toll on my WD Blue, So my question is do I get another Blue, or get a Red since I almost never turn my computer off. (My hard drive vibrates quite a bit when logging in and doing other tasks)
Gaming Rig - Excalibur - CPU: i5 6600k @ 4.1GHz, CPU Cooler: Hyper 212 Evo, Mobo: MSI Gaming M3 RAM: 16GB Corsair @2400MHz, GPU: EVGA 1060, Case: NZXT Phantom Full Tower (Red)
My Virtualization Server - Dell R710: 2x X5570s @ 2.93GHz with 32GB DDR3 RAM [Web Server, OSX, Plex, Reverse Proxy]
I love computers, gaming, coding, and photography! Be sure to quote me so I can respond to your post!
https://linustechtips.com/topic/65605-wd-red-questions/
Get another blue drive. A red drive is designed to work in a nas, not a pc. It also spins at a slower speed then a blue drive.
https://linustechtips.com/topic/65605-wd-red-questions/#findComment-896294
Really? Thought they operated at the usual 7,200rpm?
I know the Greens spin slower at 5,900rpm
But I do agree with the above poster, just get another Blue, the Red should be fine but they are quite expensive and the only real difference is that the Red's are 24/7 tested and certified.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/65605-wd-red-questions/#findComment-896308
Reds spin at 5400 rpm.
For the OP, get a blue or barracuda--whichever is cheaper.
https://linustechtips.com/topic/65605-wd-red-questions/#findComment-896331
Does anyone reccomend any other hard drives, I'm looking for speed, and reliability kinda preferring WD because they have free transfer software which only works with WD drives I believe. Idefineately don't want an SSHD though. So anyone recomend any other drives, or some disk copying software? (free disk copying software)
https://linustechtips.com/topic/65605-wd-red-questions/#findComment-896354
Running consumer drives in 24/7 is not that big of a problem in my experience.
I've had plenty of standard consumer drives (mostly Samsung) operate for 24/7
since about 2007, no problems at all (although I have now sent them into retirement
and am running some WD RE4's and WD Reds).
Google did a large-scale study on running consumer drives in their farms a few
years back, link here (pdf) if you're interested.
Bottom line: It works. thumb.gif
The Red will work just as well in a PC, it's just not very fast. I've been running
them for a few months now without issues. They are whisper quiet and produce very
little heat. :)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/65605-wd-red-questions/#findComment-896400
