Please help!
A few things come to mind. Firstly, Speedtest.net automatically picks the server that's closest to you. If you're downloading from further away, it's bound to be slower. To verify, manually pick a speedtest server that's not so close.
Secondly, there's some confusion related to downloading. You see, when you download a file, it's not just the file that's transmitted, there's lots metadata related to the routes, sizes, addresses, protocols, security and so on. That's just to say, if your download speed is 25 MBps, it does not mean you can download a file with a size of 25MB in one second. Thirdly, make note of your bits and bytes. MB is Megabytes. Mb is Megabits. One byte is eight bits. Go take a look at the Speedtest results. It's in Megabits. To make it correlate with your download speeds, you need to divide the test result by 8. Fourthly, Your ISP might be throttling downloads especially P2P. And lastly, sadly there's nothing you can really do about any of this. Be it your ISP, the ISP of the download server, some ISP in between, your dataplan, the distance etc, the issue is beyond your control. Unless your ISP actually guarantees higher download speeds, you can't even complain to them. The speedtest.net test proves your hardware and plan can do at least 7MBps down, which to me sounds like a pretty basic DSL connection. You could look into switching to fiber. But unless it's already connected, it costs like crazy.
