When you say low profile, do you mean single slot? Or is a dual slot GPU fine? :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/654986-best-card-for-mini-pc/#findComment-8407070
Low profile as in what? Low profile PCIe bracket or single slot card or what? I would recommend a RX460 but I'm not sure whether it fits in your PC or not :/
https://linustechtips.com/topic/654986-best-card-for-mini-pc/#findComment-8407348
Alright sure :D (sorry for being so condensing...)
https://linustechtips.com/topic/654986-best-card-for-mini-pc/#findComment-8407682
Best low profile card on the market is GTX 750 Ti
Example: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836
Unless you live in japan, where you can get a GTX 950: https://www.amazon.co.jp/dp/B01GDK28QO/
You should wait for the GTX 1050 for LP (or RX 460, but sadly there aren't that "many" LP AMD cards so who knows), also if you don't know the rest of system's specs it's not a good idea to upgrade like that
Card's memory doesn't influence on compatibility, the pc only needs to have a PCI-e slot. Also you need to check his pc because some prebuilts only have clearance for single slot cards.
This is a signature.
https://linustechtips.com/topic/654986-best-card-for-mini-pc/#findComment-8407939
