a 212 evo.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/654822-cpu-too-hot/#findComment-8401393
Is it idling at desktop or is it running something in the background? 70+ are load temps for a 4570 on the stock cooler, so there could be a problem if truly idling at those temps. Reseating the cooler would be an option in that case.
If you go with an aftermarket cooler, any decent air cooler will do.
https://linustechtips.com/topic/654822-cpu-too-hot/#findComment-8401405
6 minutes ago, DanTheManWithAPan said:
I have a intel i5 4570 cpu and its temps are 70+ when at desktop. I use the stock cpu, Im just wondering what would be some good choices for cooling the cpu, and whether i should go with water cooling or not.
First, open up task manager. What's the CPU usage percentage when it's 70 degrees? If it's high (<50%) then kill that process and see if the temps return to normal.
If CPU usage is low, then turn the PC off, remove the cooler, clean off the thermal paste, reapply the thermal paste, remount the cooler carefully, and see if that helps.
If nothing has worked up to this point, then buy a new cooler. No need for water cooling, just get a cheap air cooler like a 212 EVO, an H7 or a Pure Rock.
Other systems I've built:
https://linustechtips.com/topic/654822-cpu-too-hot/#findComment-8401423
