5 minutes ago, kayotics said:
I was looking for a gpu block for my radiatormcooled gpu and I noticed one that said universal gpu block, what does that mean?
A universal block is meant for GPU's that don't have a full cover waterblock made for them, usually lower end GPU's don't have full cover blocks but also in that case most times it's not worth it to watercool them.
-Moved to Liquid and Exotic Cooling-
Universal means it fits several different makes and models. GPU block cools only the GPU chip and not the VRAM or the VRM. A lot of Low-end cards don't require watercooling the VRAM and VRM. For higher-end you can get universal blocks for them too. Or ou can try and fin d a full cover block Which cools everything but is model-specific.
Universal = fits more than one type/brand of card.
Check the compatibility list on the website to see all the ones it fits.
Just now, kayotics said:
Ok cool because I have an amd card and want to water cool it due to it's 50 degrees half idling
What card do you have we can get a better idea of what you will need.
3 hours ago, kayotics said:
Well i have an amd HD 4890
Yeah that card wouldn't be worth the cost of it to watercool as the parts to just get a decent loop going would be around $400 USD which is more than the card's worth.
