No it only has support built in for wired internet. You'll meed some sort of adapter.
Try to find a wifi dongle that uses the ethernet port or usb; PCI wifi cards are just more annoying to deal with in the grand scheme of things.
I won't know you're talking to me unless you reply/quote me.
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8389223
5 minutes ago, Darkspawn said:
Hello Boys and Boys i am buying new pc and iam wondering if this motherboard GIGABYTE H110M-S2H has something like wireless internet support or i need to buy somethig like
TP-LINK TL-WN722N  or Edimax EN-9235TX-32 V2
Thanks for your help !
you would need something like the pcpartpicker.com/product/G4H323/tp-link-wireless-network-card-tlwdn4800 its a wireless wifi connector through pcie slot make sure your MOBO has one of these slots
not necassarily need a dongle you can use a pcie wireless adapter or a usb wifi adapter
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8389236
12 minutes ago, Canada EH said:
Dont bother with H110, go with a better one like a B series.
I second this, the extra RAM slots can come in handy when you upgarde your RAM in the future.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8389283
I have very limited budget so i just cant buy 150€ motherboard, but i think buying  usb / pci is good and cheap solution. And why should i not bother with H110?  (iam not pthinking about overclocking and adding 25 additional RAMs) so i just want something that will work + support ddr4 ram and my processor + (my budget 60€ in my country)
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8389293
B150 boards are usually only slightly more expensive. Where you buying it from?
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8389323
iam buying all part from one shop ( its in my language so you will not understand a single word) basicaly, pc component which costs 100dollars(in USA) will cost here 100euros + 5-20% more :/
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8389381
10 hours ago, Darkspawn said:
I can take this one b150m-a   BUT i cant find any  pci/usb adapter, i want something that doesnt require installation, just want to put in and Bang i can go on internet
How expensive is it in comparison to the board you were looking at?
For the Wireless adapter the Tp-link one is the obvious choice, the other card is wired only!
https://linustechtips.com/topic/653458-iam-noob-i-need-help/#findComment-8391425
