So the pc that my mother and sister use has this problem. Try to power it on and the cpu, psu fan will start spinning and stop. Green light on the board, I've tried all the ram slots, I've disconnected the 4 pin, 24 pin, psu, 6 pin pci-e and plugged them all back in several times, reset cmos etc. It's done this before and I just unplugged everything and plugged it back it and it came on after 2-4 tries and worked for a couple months. I don't know what could be causing this.
What should I try?
Amd Athlon 5600
Asus MZN SLI Deluxe mobo
1 GB of OC
7900 GS
600w OCZ psu
https://linustechtips.com/topic/65343-not-a-common-power-issue/
i dont know.. did it get water spilled on it?
𝘛𝘳𝘶𝘴𝘵 𝘺𝘰𝘶𝘳 𝘪𝘯𝘵𝘶𝘪𝘵𝘪𝘰𝘯
PC: ibuypower pre-built RDY Y70
Cpu: i9 14900K  Gpu: Zotac 4070 super ti  Ram: 32Gb DDR5  SSD: 2Tb
Case: HYTE Y70  MB: MSI 790-P wifi
Cooling: ibuypower 360mm RGB aio
Laptop: Lenovo Legion Pro 5i, u9 275HX, 32gb ddr5, 5070ti, 1tb SSD, 16" 165hz oled
https://linustechtips.com/topic/65343-not-a-common-power-issue/#findComment-893088
I think theres something wrong with mobo itself. I don't know excatly what. My old mobo did something similliar where it sometimes crashed to POST screen and continued after several reboots and disconnecting power cord for few mins. It did it with old CM psu and new Thermaltake psu.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/65343-not-a-common-power-issue/#findComment-898245
