I want to build a nice new build for around 1000 or 1100 USD. The main use would be for gaming and general use.
I want:
a quad core, preferably with hyperthreading,
16 GB RAM,
And an SSD for the OS
I also need a monitor, preferably 1080p, but if there is a 1440p monitor for a comparable price, that would be fine. The monitor doesn't have to be included in the price above.
My preferred case is either an NZXT Noctis 450 or the Corsair SPEC-ALPHA.
I do appreciate the help, so thank you in advance.
Edit 1: I'd prefer it to handle 1080p very easily, I'm not looking for superb quality, but I'd at least want it to run GTAV smoothly.
https://linustechtips.com/topic/653424-first-pc-build/
Will you be overclocking?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388879
for what use?
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388891
Maybe something like this:
http://pcpartpicker.com/list/YXvtnn
Laptop:
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388897
http://pcpartpicker.com/list/WBZ78K there got you basically an I7
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388898
Laptop:
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388906
1 minute ago, PCNoobie said:
You can't overclock the cpu with h110m mobo.
Edit: wrong guy XD.
your build got destroyed by mine. :)
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388915
1 minute ago, CUDA_Cores said:
This build is too cookie cutter, I'll let the others handle this.
nice why not throw in a build
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388926
agreed. I messed up.
i made this one which is better
http://pcpartpicker.com/list/83tFgL
Laptop:
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388927
1 minute ago, Elbigmac said:
I'm liking this, but is the SSD going to be reliable? I'm not familiar with them .
they are good. not as good as samsung but good
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388928
yeah but still a 1060
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388929
Just now, Elbigmac said:
I'd change the case to one of my preferred but I'll consider this.
is an I7 for 50$ cheeper with a 1070
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388935
But you cant overclock a Xeon, and the clock speed is less
Laptop:
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388938
you can science studio has
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388941
Show me. (Not just upping the FSB speed.. legit overclocking)
Laptop:
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388947
PCPartPicker part list: http://pcpartpicker.com/list/W682m8
Price breakdown by merchant: http://pcpartpicker.com/list/W682m8/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($294.99 @ SuperBiiz)
Motherboard: ASRock H170A-X1 ATX LGA1151 Motherboard  ($76.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($60.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($88.48 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: Asus GeForce GTX 1070 8GB Video Card  ($424.99 @ SuperBiiz)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($136.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($58.99 @ SuperBiiz)
Total: $1189.90
Generated by PCPartPicker 2016-09-02 01:05 EDT-0400
https://linustechtips.com/topic/653424-first-pc-build/#findComment-8388957
