Nvidia Quadro and Intel Xeon. [Build] HELP!!!
Go to solution Solved by Electronics Wizardy,
Id get a geforce card, it won't help to get a quadro for your uses. Id get something like a gtx 960.
Id get a more modern i5 or i7. A old xeon won't help at all.
Do you have a budget?
If you want a fast system on a budget, look a something like used dell t7600. Its dual lga 2011, which you can put dual 8 cores in for about 700 total.
Fib2sWc.png "Hello! my niggas".
Will I know all thinks mainstream computers Linus, thanks for everything, but I came here because I know not many about for Xeon and Workstation GPUs.
I need all folks here tell me that CPUs are the best for these Quadro cards, please be direct and explain the reason why the best procedure. I do not want bottlenecks, I wanna get the maximum torque of the theses cards.
I have a little idea for the FP64 performance on GPUs.
For what I need my computer?, I need for Maya, Blender and SFM Animations Renders.
I have two options, keep my old and actual PC and only change the CPU and GPU for Xeon and Quadro.
NOTE:  I have a job a lot and, not have employ, and save money for this i not have many money. this are the reason for what i chose used parts.
I you reply my question please try reply with i3xxx i5xx series equivalents
Reply Example:  this are because i wanna know the normal equivalent and Xeon series at same time
Xeon E3120 2 core Wolfdale = Normal Equivalent =  Core 2 Duo E8600 Wolfdale 2-Core
Nvidia Quadro 4000
My actual PC are.
FOXCONN G31MV-K
Bus Type    Dual DDR2 SDRAM 4GB 667 MHz
Sapphire HD 6450 1GB DDR3
DualCore Intel Core 2 Duo E7200, 2533 MHz CPU Wolfdale
64Bit
And can upgrade for this? Is Right? not have a bottleneck?
Xeon E3110
Xeon E3120
Nvidia Quadro 4000
The other question are what are the best CPUs for this Quadro cards?.
NVIDIA Quadro 6000
NVIDIA Quadro 5000
Nvidia Quadro 4000
The other question is what are the AMD Fire pro Equivalent for the cards listed up? and what is the best AMD Opteron for the equivalent cards?
This are all folks!
https://linustechtips.com/topic/653162-nvidia-quadro-and-intel-xeon-build-help/
