I build a new monster and confused between going for h110i,h115i or custom cooling to keep it calm.
Pc specs are:
Processor:i7 6950x
Gpu:titan x
Ram:trident z 3200mhz c14 128gb
Ssd:samsung 950 pro 512gb
Motherboard:msi x99 god like gaming
Psu/smps:1500iAX corsair
Hdd:wd gold datacenter 6tb and wd black 6tb
I will be glad if anyone have a cool suggestion for cabinet too
https://linustechtips.com/topic/652245-air-aoi-or-custom-cooling/
If you can afford to spend the arm and leg on that system then go all out and go custom.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
1 minute ago, W-L said:
Welcome to the Forums!
If you wanted to keep things low maintenance a 280mm AIO would be a good option for that CPU since it has a high heat output.
-Moved to Liquid and Exotic Cooling-
I feel that for overclocking AIO doent perform the notch and if i dont overclock this cpu then there is no meaning in buying that shit
It would be able to cool it but not quietly if you wanted to do overclocking, there are 360mm AIO's or units like the EKWB Predator. For a custom loop the main benefit that is gained is the ability to add a lot of rad space to give more potential cooling and to do so silently while at load.
The NZXT Kraken X61 is one of the best 280mm AIO's. As far as Custom liquid cooling, no there is NOT a good ROI or Price to Performance against it. You will likely only see 1-3c on average compared to a good AIO cooler like the Kraken x61 or EK Predator series.
Community Standards
"Beast Mode"
1 minute ago, Roger ghost said:
Saying of knowledge i am on my way of achieving it badly
just watch a bunch of build logs / guides look up jayztwocents and bit wit has a few watercooling guides
CEO of Infinity Creations
No current PC but on the WAY!
5 minutes ago, Roger ghost said:
Any suggestion for cases if opt for custom and if opt for aio
Might as well go all out and grab a Caselabs case.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
38 minutes ago, Roger ghost said:
Any good names
Choose whichever you want. Check out Ronsanut and singularitycomputers on youtube, they use Caselabs cases a lot.
