Not sure why it's doing this, but it'll turbo to 4.2 when I'm on the desktop or chrome just fine.
But as soon as I hop in a game, or run Cinebench or anything game related it won't go passed
3.8. It can't be temps because I have an H60, and CPU only goes to about 54c max when I'm
running stress tests with a 38c summer ambient temperature.
I had it overclocked to 4.5, but for some reason it spiked up to 71c, so I just reset it to defaults.
Turbo is on and everything's normal. It just doesn't seem to turbo in game. Very frustrating since
that 400mhz is quite a bit to miss out on.
Ideas?
Ryzen 7 2700x, MSI Gaming X RX 480 8gb, Asus ROG X470 Gaming, 2x8gb Corsair Vengeance LPX 3000, 120gb Kingston SSD (Boot) + 1TB Seagate Barracuda.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/
Perhaps AMD is crippling their CPU's to "encourage" adoption rates...
Have you tried any benchmarks? Do you use V-Sync?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370579
No, I never use V-Sync. And yea it turbos fine in things like firestrike, passmark etc, but not Cinebench or games
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370584
1 minute ago, Bubblewhale said:
Just don't bother with TurboCore at all, it's usually best if turned off when overclocking.
I disabled my overclock, I'm not trying to overclock right now. I might give it a go again in a couple weeks.
So until then, I just reset to default and was just going to rely on the turbo. But the only time it won't turbo
to 4.2 is in games, which is ridiculous.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370587
Yeah TurboCore is pretty much useless, It caused freezing problems for me and spiked voltage to 1.47V for 3.5-4GHZ...
Just disable it and keep it at the full 4.5GHZ.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370594
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370595
Ah okay, sucks it's not reliable.
And okay, I wanna put it back to 4.5, but the temps worried me. I use HWmonitor for checking temps. There's 2
options, so I'm not sure what's the correct CPU temp and what's socket.
Under temperatures it says CPU, and Mainboard. CPU on this one would hit 61c under max load.
But there's another under the CPU name saying Temperature > package 71c. Not sure if that's safe or even normal.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370604
2 minutes ago, GalacticRuler said:
Just disable turbo and overclock the speed to 4.2. If the chip can turbo to 4.2 on that voltage and keep reasonable temps, it can do that as a base clock.
Oh okay, yea I might do that. Temps are fine at 4.2. Should I just raise the multiplier and leave the voltage at auto? Or should I just manually set it to 1.4?
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370607
I wouldn't really worry much with a 6300 on that cooler and board, considering 6300 is okay up to 70C..
You should be worried more about CPU over Package..
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370609
If the base voltage is normally 1.4, I would manually set it that way so it doesn't decide to lower the voltage and crash itself.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370614
Oh okay. So the first temperature that says CPU, that's the temperature I should keep an eye on?
What's the one underneath the actual CPU name then?
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370617
Yeaup, when it actually turbos, the voltage at max 1.404. So alright thank you
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370619
I'd just make sure to keep it under 70C for Package temp, and 64C for CPU temp displaying under the board board.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370632
Turbo on AMD FX lines is only for 1 core, when using multi threaded cores Turbo wont trigger and stay off. so your best bet is to give a moderate overclock.
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370639
Ooh okay, that makes sense.
Thanks for the info guys, I'll just overclock again and forget about turbo.
Thanks [:
https://linustechtips.com/topic/651505-fx-6300-not-turboing/#findComment-8370644
