Right before we start quick info.
My case is rack mounted so this is why i have need for a blow fan as airflow is limited.
I'm already running 2x FD 60mm fans, 2x FD 80mm fans and a AIO water cooler with 2 pressure optimized Phantek fans.
Ii will be eventually modding the case so i can flip the PSU so it has its own airflow but that's for another day.
so i need a blower fan to help draw the GPU heat out the case better.
so my question, does anyone know a decent PCI blower that dosnt sound like a helicopter taking off and has some good air flow? ( and possibly runs off either 3pin or 4pin header? )
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
https://linustechtips.com/topic/651181-pci-blower-card/
2 minutes ago, Ykno said:
-snip-
Why didn't you buy a reference cooler?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/651181-pci-blower-card/#findComment-8366755
because i have had this PC for over a year and it wasn't always rack mounted its a new thing i been working on temps arnt bad can play games with out going anywhere near max temps but when i see room for improvement i will try it so
https://linustechtips.com/topic/651181-pci-blower-card/#findComment-8366770
