i seem to be having a problem where whenever i try launch a program it gets stuck as a background posses. ive tried restarting the pc, defraging the hdd. i did however notice that my hard drive runs abnormally slow. its a 2 TB Toshiba 7200RPM drive but for some reason it copies and moves files really slowly. the problem of programs not launching is intermittent but i noticed that in normally occurs when the disk usage is at 50%+ but the strange thing is that the 50%+ disk usage is coming from programs that only utilizing less than 1MB read or write. is there any suggestions that anyone can give me other than getting a new drive because i dont have the money for a new drive.
EDIT________
after some more digging the issue seems to be that my storage disk is running at 100%active time. ive tried disabling super fetch and windows search . i run my OS (Windows 10) from a 240 GB ssd and use my 2TB toshiba HDD to store games and stuff on but evrytime at startup it gets pinned at 100% usage and i dont know why, since i cant tell which programs are running from witch drive
I included a dxdiag.txt file for the specs and stuff.
my antivirus is 'trend micro Titanium' i also have 'PC Cleaner Platinum' installed as well as 'driver navigator'
DxDiag.txt
https://linustechtips.com/topic/651098-serious-disk-problems-100-usage-on-disk-1/
Try a S.M.A.R.T hdd scanner, your hard drive is probably failing
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
Check S.M.A.R.T, the hard drive is probably throttling.
Lenovo/IBM ThinkPad T61 Widescreen 15.4" 1680x1050
Intel Core2Duo T8300 2.4GHz | 3GB DDR2 from Hynix | SATA II Patched bios (Middleton) | Samsung EVO 850
Arch Linux | Linux 4.3.X x86_64
1. Download HDTUNE and check the disk health or scan for bad sector.
2. You can try run the built-in benchmark.
3. If you're copying many small size files it will take much much longer.
would crystal disk info have something similar?
Check if your HDD is failing first, I recommend this software http://www.passmark.com/products/diskcheckup.htm
okay so after a little more digging it seems that my hdd is stuck at 100% disk usage or active time. but i dont know what program is using my disk because i have the OS running off my SSD and the and the  2TB Toshiba is the storage drive.
