C# Help getting values from the registry
Go to solution Solved by AlTech,
@vorticalbox So I found the issue xD. I'm a little embarrassed.
The issue was a typo...........
edition = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "EditionID", "Windows version not detected");
            buildBranch = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "BuildBranch", "Windows build branch not detected");
            CurrentBuild = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "CurrentBuildNumber", "Windows build number not detected");
            productName = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "ProductName", "Windows product name not detected");
            release = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "ReleaseID", "Windows release not detected");
            productID = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "ProductID", "Windows product ID not detected");
            owner = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion", "RegisteredOwner", "Windows owner not detected");           [/Code]
Hi guys,
I'm trying to get information from the registry and I can't seem to do so............
Here's the relevant code:
        object edition;
        object buildBranch;
        object CurrentBuild;
        object productName;
        object release;
        object productID;
        object owner;
  edition = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "EditionID", "Windows version not detected");
            buildBranch = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "BuildBranch", "Windows build branch not detected");
            CurrentBuild = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "CurrentBuildNumber", "Windows build number not detected");
            productName = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "ProductName", "Windows product name not detected");
            release = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "ReleaseID", "Windows release not detected");
            productID = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "ProductID", "Windows product ID not detected");
            owner = Registry.GetValue("HKEY_LOCAL_MACHINE\\SOFTWARE\\Windows NT\\CurrentVersion", "RegisteredOwner", "Windows owner not detected");
releaseVersion.Text = Convert.ToString(release);
            osbuild.Text = Convert.ToString(CurrentBuild);
            branch.Text = Convert.ToString(buildBranch);
            ownerBox.Text = Convert.ToString(owner);
Thanks a bunch :).
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/649854-c-help-getting-values-from-the-registry/
try
using (Microsoft.Win32.RegistryKey key =
       Microsoft.Win32.Registry.LocalMachine
               .OpenSubKey(@"SOFTWARE\Microsoft\WindowsNT\CurrentVersion"))
    var osVersion = key.GetValue("CurrentVersion");
You can also use Environment.OSVersion
Console.WriteLine("OSVersion: {0}", Environment.OSVersion.ToString());
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
10 minutes ago, vorticalbox said:
try
environment.osversion doesn't return the correct value under Windows 10. It says 6.3 instead of 10.0
I'll try what you suggested when I'm at my desktop
ill tty what you suggested when I'm at my desktop
https://msdn.microsoft.com/en-gb/library/windows/desktop/ms724832(v=vs.85).aspx?f=255&MSPPError=-2147217396
39 minutes ago, vorticalbox said:
* For applications that have been manifested for Windows 8.1 or Windows 10. Applications not manifested for Windows 8.1 or Windows 10 will return the Windows 8 OS version value (6.2). To manifest your applications for Windows 8.1 or Windows 10, refer to Targeting your application for Windows.
17 minutes ago, AluminiumTech said:
I know thats why i sent you there so you can target your applications :P
