Hello there, I was in the process of installing my EKWB waterblock on my card but when came the moment to remove the fan and RGB plugs, one was difficult enough to remove but the other one doesn't want to move at all. I tried to check installation guides on youtube to see how they did it, but most of them are for the gtx 1080 FE when I have the strix version which is totally different.
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/
Try to wiggle it a bit and if it doesn't work, why not cut the cables in the middle?  If you ever need the original strix cooler again you could solder the wires back together ( they are color coded so nothing too difficult)
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351503
meh, I need to put the EKWB waterblock and backplate on it afterwards, having a connector with hanging out cable isnt the best. It literally doesn't move, I did the wiggle for the other one but this one doesn't move at all.
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351513
try a bit more force, it'll give, just dont rip the solder pads :P
these connectors are very finnicky, if you're 100% sure it's stuck, grab a hobby knife, and stick it into the plug above the connector and pry ever so slightly while wiggling.
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351525
http://i.imgur.com/spIEj3R.jpg
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351526
they're not clips, they're just protrusions in the connector, you cant really push them.
i know from expeirence from seeing pretty much hundreds of these over the years :P
best thing to do is lift the black connector up, so it doesnt grab as hard.
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351531
well... then smash a blunt object in there to make it move
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351590
Iv'e been wiggling it for the past hour. It moved at first for about 1mm then nothing more. It still wiggles but doesn't go further than that.
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351594
try gently prying at it with a hobby knife or something similar. like i said, they're finnicky xD
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351630
yeah well, a little bit of the top of the black plastic holder cracked and broke off when I pried it just a little bit so I won't do that anymore xD
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351642
https://linustechtips.com/topic/649513-rgb-plug-is-stuck/#findComment-8351660
