making a pc for friend not a big deal if i go over budget for 1080p needs to play games like witcher,csgo,lol,military simulators (arma),gta and ww2 games willing to go used if good deal and this pc must be on ddr3 already has 16gb of ddr3 and a case
https://linustechtips.com/topic/648981-build-help/
What sort of budget are we talking here??
If all he needs is 1080P you'll want an RX480 for a GPU, price/performance is brilliant
As far as CPU's go, I really have no clue, unless you want to wait for ZEN :P
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/648981-build-help/#findComment-8346455
1 hour ago, The Flying Sloth said:
So you'll want an RX480 for a GPU
he won't wait
https://linustechtips.com/topic/648981-build-help/#findComment-8346465
1 minute ago, masterkickass7 said:
he won't wait
Without knowing your budget I really can't recommend a CPU :)
You'll want an i5 minimum, don't bother looking into AMD chips, they are old tech ATM and unless you can get an 8350 secondhand for a freaking amazing price it's not worth it
@rice guru
https://linustechtips.com/topic/648981-build-help/#findComment-8346475
anywhere from $400 to $1000
https://linustechtips.com/topic/648981-build-help/#findComment-8346482
So a 480 is $200, an i5 6400 or i5 6500 should be about where to aim at for CPU. case is completely aesthetic and up to your friend, motherboard doesn't need to be overly expensive as he won't be overclocking those chips :P . I've always used Antec's HCG lineup of PSU's but I am aware that many people don't like them so again your choice, aim for 700w so you can upgrade in the future if need be.
That's my 2c anyway, good luck with your build
@rice guru
https://linustechtips.com/topic/648981-build-help/#findComment-8346510
