Just turned on my pc, playing a game and noticed that my gun would randomly start aiming (right click) even thought I didn't press it
got off my game and when i put my mouse on the desktop and left it, it would right click. It is very annoying and don't know how to fix it, I doubt my mouse is stuck.
Help
https://linustechtips.com/topic/648254-random-right-clicks/
Looks like your mouse is dying...
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338501
Just now, NinJake said:
Thanks for your response. Does your mouse always right click, even if you don't left click for a while? (Keep your mouse on desktop, wait for right click, then slightly move the cursor somewhere else and wait and see if it right clicks again)
yeah, even if I don't touch it, it would right click. It started today for the very first time.
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338506
Since it just started happening today. Try turning off your PC. A full shut down, and once it's rebooted and you are back on your desktop, unplug your USB mouse and try a different USB port.
earlier I restarted my PC and it didn't do the right click thing for the first hour, afterwards it started doing it again.
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338534
malware maybe?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338537
I think it's strange that it worked fine after rebooting your computer but started back up after 1 hour. I would try rebooting again but take note of what you do when it starts happening again. (Launching a specific program, load a particular website)
If you have the time, reboot your computer and just let it sit there and wait to see if it happens without any other user interference.
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338556
It did happen as soon as I opened Discord but i doubt that's the problem because I closed it and it still kept doing it.
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338569
Check if you have any updates to your mouse drivers, or to discord. Once updated, reboot and see if it is fixed. If it keeps acting up, reboot and don't use discord for a while and see if your mouse works fine.
If it only happens after launching discord, uninstall it and reinstall it, in case of a corrupt file.
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338583
Just now, JokerProduction said:
Assuming you dont live alone i would also check and make sure theres not a micro usb dongle in one of the usb ports.  Wouldnt be the first time someone has fallen for that prank...
there isn't. No one in my house is smart enough for that.
https://linustechtips.com/topic/648254-random-right-clicks/#findComment-8338622
