i want replace a stock fan corsair h100i with Enermax Magma..but i get confused with the fan connector..connector from h100i is 4 pins while connector slot at enermax magma just 3..u guys can refer the picture i attached. can i just connect them? but if i do so..there is 1 pin is not connected to slot.thx in advance !!
*** Core i5 4670k - MSI z87 GD45 - Sapphire Vapor X HD7950 - Corsair H100i - NZXT Phantom 410 - Dell 23'' U2312HM - Blackwidow Ultimate - G502 Proteus Core - Siberia v2 Frost Blue***
https://linustechtips.com/topic/64825-silly-question-herebut-i-need-a-help/
yes
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
Yes, the 4th pin is an optional PWM pin which helps with fan control (if your fan supports it) but is not required.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
The 4th pin is the PWM pin.
You can still plug 3pin fan connectors into it, you just leave the 4th pin alone.
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
