Just now, Leej065 said:
Ok this may seem stupid but I've just bought an ssd and would like to put Windows on it will I have to completely wipe my  Hdd to be able to put Windows on the ssd?
you could clone it
Mouse: Logitech g402 <3
Keyboard: Some Tenkeyless with blue kalih switches
Headphones: Logitech g430
Monitor: HP w2207h (1680 x 1050 @ 60hz)
PC Specs:CPU(AMD A8 6500 @3.5ghz), Mobo ( ASUS A68HM-E  FM2+), 1x1600mhz 4gb stick of ram, Random grey PSU, 920gb ssd
PhoneIphone 5 32gb
Tablet: Ipad 2 16gb
Laptop:Toshiba satelite with 8gb of ram a 480gb ssd and a mobile 2nd gen I3
https://linustechtips.com/topic/647430-help-with-adding-an-ssd/#findComment-8329849
1) unplug HDD
2) plug in SSD
3) install windows http://www.howtogeek.com/224342/how-to-clean-install-windows-10/
4) plug in HDD (make sure you DO NOT boot into the HDD, you want to boot into SSD, this can be set in the UEFI boot priorities)
5) if possible, move your files to the SSD, format the HDD, then move the files back
6) if not, then try to delete the windows files from the HDD leaving just your user files like documents and videos and stuff
7) reinstall your programs
https://linustechtips.com/topic/647430-help-with-adding-an-ssd/#findComment-8329862
42 minutes ago, lopj245 said:
I'm not a fan of cloning drives, I would honestly just create backups of anything important such as photos and docs and then do a clean install however that is up to your discretion.
I would second this. Even if you don't plan on wiping it I would make backups just in case.
If you are installing to the SSD, you can remove your HDD and have the boot priority to your Windows boot device. Install the OS on the SSD (you could possibly do it while it's still installed, just look for the drive that matches your SSD capacity). Make sure in your BIOS you have the boot priority set to the SSD and not the HDD.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/647430-help-with-adding-an-ssd/#findComment-8330066
