hi,
so I have an i7 4790k with GTX980 and 16g DDR on an Asus Maximus Hero VII and win10 64bit.
Recently I encountered some bios problems(i was trying to be a smart-ass) so I had to reset the bios and since then I have a kinda laggy PC, but my big problem is that now Sony Vegas Pro 13 won't render at 1440p because the CPU goes instantly at 100%, if I render at 1080 60fps it barely works. Previously I didn't have this problem.
thank you
https://linustechtips.com/topic/647375-bios-cpu-problem/
22 minutes ago, Mr.C said:
sorry, I forgot to tell that I am not by no means an expert.
Sadly don't know what OCED means - but it definitely worked better before, Sony is my biggest concern now
Allocate more RAM to it the default is pretty low so change it to 6gb or 8gb
https://linustechtips.com/topic/647375-bios-cpu-problem/#findComment-8329342
10 minutes ago, Mr.C said:
but i have 16?it doesn't use it all?how do i do that
thank you
I don't know how in 13 but I know in 11 hopefully someone comes to this thread to check. My Sony Vegas 11 uses 3 by default and that was quite the lagfest. Change it to 6gb and then see if it works from there .
https://linustechtips.com/topic/647375-bios-cpu-problem/#findComment-8329350
OCd means overclocked, its not OCED, its OCd anyway im not sure what the problem is but try reseting BIOS or updating it, might help you
Builds:
https://linustechtips.com/topic/647375-bios-cpu-problem/#findComment-8329368
