Hi!
made this post cause I wondered if my CPU can read the right temps when its minus degrees celsius.
My CPU reads -11C, while my phase change is pendling between -44,5C and -45C.
So is my CPU doing the right readings?
**edit, Solved!! Answear: Right readings**
Edited by Republic
Intel Core i7-4790K 4.9GHz Quad-Core Asus MAXIMUS VII HERO ATX LGA1150 | G.Skill Trident X Series 32GB (4 x 8GB) DDR3-2400 2X Samsung 850 Pro Series 256GB 2.5" SSD (Raid zero) Seagate Barracuda 2TB 3.5" 7200RPM Seagate Barracuda 3TB 3.5" 7200RPM Evga Gtx 980 Ti SC 6GB SLI Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Asus PCE-AC88 PCI-Express x1 802.11a/b/g/n/ac
LD PC-V10 Phase Change - Black White NZXT Hue+ Coolermaster MECH | Corsair M65 RGB Acer Predator x34
https://linustechtips.com/topic/647369-cpu-sub-zero-temp-reading/
-45C is the evaporator head temp, it is not the CPU temp which is a lot hotter than that.
It might be some other temp are you sure your reading it stating your CPU Temp?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Quite sure it's reading the CPU, but I am not sure if its reading right
-11C is correct.
Just now, Enderman said:
-11C is correct.
Thx, Guess I will have to delidd it again, and remove the heatspreader to get the temps lower. Thanks for quick reply ^^
18 minutes ago, Enderman said:
-11C is correct.
Nice joke m8
Great joke. Did you guys plan this?
Just now, Jack Dvorak said:
Nice joke m8
Lol, was actualy dead serious. As the temp goes from -2 to -11 once I start Aisuite :P
Still learning, even though I am going a bit overboard extreme with my setup ^^
6 minutes ago, Jack Dvorak said:
Nice joke m8
How is that a joke...
Do you know what phase change is?
That's one weird glitch dude.
EDIT: wait a second are you doing ln2 cooling RN?
4 minutes ago, Jack Dvorak said:
Yeah I just realized that. I'm so tired...
Haha, no worries. Just needed to know if my CPU was reading right temps or not, as Aisuite reads something and other programs reads 0 :P
*edit* Yes, doing Phase Change from LDcooling
Edited by Republic
