Planning my first build, a computer to do some gaming (good, but not ultra HD, mega brain-splosion gaming).
Budget is around £500 (I've found some cheaper prices for these parts elsewhere) running 2 monitors, carrying out web development, schoolwork etc and basically an upgrade from my old laptop.
Here's my parts list, any suggestions? Any mistakes I've made?
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£181.99 @ Amazon UK)
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard  (£48.99 @ Amazon UK)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (£25.99 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£45.48 @ Ebuyer)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  (£188.99 @ Ebuyer)
Case: Aerocool Qx-2000 MicroATX Mini Tower Case
Power Supply: Antec High Current Gamer 520W 80+ Bronze Certified ATX Power Supply  (£54.95 @ Overclockers.co.uk)
Operating System: Microsoft Windows 10 Home Full 32/64-bit  (£85.98 @ Ebuyer)
Total: £632.37
Generated by PCPartPicker 2016-08-21 22:02 BST+0100
https://linustechtips.com/topic/646876-planning-first-build/
Do you have an existing hard drive you can re-purpose? If so I would suggest swapping out the 1TB drive for a 120GB to 240GB SSD as you'll definitely notice the increase in load times all around.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/646876-planning-first-build/#findComment-8323808
Nope everything would have to be new, I was looking at SSD's because the performance difference is more than noteworthy. But I don't think it's something I'd go with.
https://linustechtips.com/topic/646876-planning-first-build/#findComment-8323812
I have a 1TB HDD, and I have used a PC with an SSD. I honestly don't get the hype. My PC actually boots into Windows faster than my friends' SSD equipped machine.
https://linustechtips.com/topic/646876-planning-first-build/#findComment-8323844
