Help explaining/choosing pwm splitters
So guys, Ive finally managed to but a new case (airflow 540) and a h100i cooler.
Now the mobo that I have is crap http://www.asus.com/uk/Motherboards/P8Z77V_LX2#specifications
I believe that it has 3 pwm fan spaces on this particular model, what I am wanting to do is attach 4 fans to one slot (push/pull h100i) 2 front intake fans as intake and 1 rear exhaust.
So Im guessing that I will need 2 splitters of some sort, could someone with more knowledge than me provide a link to the actual items that I need (amazon uk or something)
Thanks In advance
Pixel
http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026 ?
You can use the hub on the H100i and use fan control through that.
If you want to go with the splitting route anyway, make sure your headers can provide enough amps to run two fans. (you should be fine but check anyway)
