GTX 970 at 0-1% Load, but 40 degrees on idle?
23 minutes ago, JWolfCrafter said:I have no idea why my card is being so hot on idle. Normally it hovers around 29 degrees to 32 degrees, but now its getting up to 40? The red bar in PrecisionX (Picture 1) is also normally all the way down and not filled at all.
Pictures (In top-down order): PrecisionX, GPU-Z (Graphics Card Tab), GPU-Z (Sensors Tab), Task Manager (Processes Tab)
I ran MalwareBytes once, restarted after removing all the stuff it said to, ran it again and it came up as 0 viruses found. Problem is still here.
The reason why it's so "hot" is because the clocks are high, even on idle. This could be caused by a number of reasons, multi-monitor setups and having the power preference set to maximum performance being 2 of them that immediately come to mind. Have your card downclock and temps will go down.
With that said, though, I wouldn't worry about it. Not one bit. 40C is perfectly fine. To be honest, your card shouldn't even be idling in the first place, consider that a bonus.
