Posted August 19, 2016 i just got my hard drive and installed it on my computer and at first it was detected as a disk drive because of power.iso so uninstalled the program and it wont show up the only thing it will show up on is device manager and idk how to fix it from there and it wont show on disk management Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Go Into a CMD Type "diskpart" in the new window type "list disk" Can you see the disk? CPU: Intel Core i7-7700 GPU: NVIDIA GTX 1070 Cooling: N/A Motherboard: N/A Ram: 32GB HDD: 4TB RAID 1 Array (two 4TB) PSU: N/A Case: N/A OS: Windows 10 Mouse: Something Something Logitech Keyboard: Razer Blackwidow 2016 Headphones: Audio Technica ATH-M40X Speakers: ??? Monitor: 2 x HP 22cwa Phone: OnePlus 3T (T-Mobile Network) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 If it shows up in device manger but not in file explorer, it could be there isn't a partition assigned to it. Opening up Disk Manager and assigning a partition might fix it. http://knowledge.seagate.com/articles/en_US/FAQ/188931en?language=en_US Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Author 3 minutes ago, Divide_By_0 said: Go Into a CMD Type "diskpart" in the new window type "list disk" Can you see the disk? it didnt show show up Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Author 3 minutes ago, TheCi said: If it shows up in device manger but not in file explorer, it could be there isn't a partition assigned to it. Opening up Disk Manager and assigning a partition might fix it. http://knowledge.seagate.com/articles/en_US/FAQ/188931en?language=en_US it doesent show up in disk management Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Just now, Batman3948 said: it didnt show show up Try and uninstall the disk and reinstall it into the device. CPU: Intel Core i7-7700 GPU: NVIDIA GTX 1070 Cooling: N/A Motherboard: N/A Ram: 32GB HDD: 4TB RAID 1 Array (two 4TB) PSU: N/A Case: N/A OS: Windows 10 Mouse: Something Something Logitech Keyboard: Razer Blackwidow 2016 Headphones: Audio Technica ATH-M40X Speakers: ??? Monitor: 2 x HP 22cwa Phone: OnePlus 3T (T-Mobile Network) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Author Just now, Divide_By_0 said: Try and uninstall the disk and reinstall it into the device. i tried that and it didnt work Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 21 minutes ago, Batman3948 said: i just got my hard drive and installed it on my computer and at first it was detected as a disk drive because of power.iso so uninstalled the program and it wont show up the only thing it will show up on is device manager and idk how to fix it from there and it wont show on disk management Are you sure you plugged it in correctly? Both SATA data and power? I edit my posts a lot. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Author 2 minutes ago, MrDrWho13 said: Are you sure you plugged it in correctly? Both SATA data and power? yes becuase it comes up in device manager and i can hear it boot up when i listen up close Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 Author i got it to work i went on manage storage spaces and put no resiliency and clicked create space or somthing like that and now its working Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 19, 2016 lol wow CPU: Intel Core i7-7700 GPU: NVIDIA GTX 1070 Cooling: N/A Motherboard: N/A Ram: 32GB HDD: 4TB RAID 1 Array (two 4TB) PSU: N/A Case: N/A OS: Windows 10 Mouse: Something Something Logitech Keyboard: Razer Blackwidow 2016 Headphones: Audio Technica ATH-M40X Speakers: ??? Monitor: 2 x HP 22cwa Phone: OnePlus 3T (T-Mobile Network) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
