Hello all people on this forum!
I have some problems with my computer that im not able to fix by myself so im hoping that somebody here can help me fix it.
It started after i updated to windows 10, when i started Overwatch and played for a couple minutes and the game crashed (static sound and screen went black and said no signal). I thought it was some driver that was up to date so i updated every driver that i could find that was out of date. But that didn't fix the problem so i thought it was something wrong with the powersupply (it was an old one) so i bought a new one. But after installing it i went back to play overwatch but the same thing happend.
Have anybody experienced anything similar?
With best regards //McFlaffCpuid.jpg
https://linustechtips.com/topic/645771-computer-problem/
is anything in your PC overclocked?
Builds:
https://linustechtips.com/topic/645771-computer-problem/#findComment-8311624
Just now, McFlaff said:
No hardware in my computer has ever been overclocked
maybe try reinstalling the game?
Builds:
https://linustechtips.com/topic/645771-computer-problem/#findComment-8311637
1 minute ago, McFlaff said:
I´ve done that, the weird thing is that all the games i try is crashing after a while
check all cables in your PC, try reseting CMOS, check that your GPU isnt falling out or something and if non of that works you could try reinstallling windows
Builds:
https://linustechtips.com/topic/645771-computer-problem/#findComment-8311681
Already updated the cmos and checked that everything is in its place, so i might have to reinstall windows
https://linustechtips.com/topic/645771-computer-problem/#findComment-8311734
well i dont know what else to do tbh, look around on the web, google might find something for you
Builds:
https://linustechtips.com/topic/645771-computer-problem/#findComment-8311737
51 minutes ago, Litargirio said:
Can you please elaborate a bit? What exactly do you mean by "no signal"?
When im playing the game, after a while the screen will go black and there a small blue popup will say no signal and static sound will play through the speakers
https://linustechtips.com/topic/645771-computer-problem/#findComment-8312133
Hmmm sounds like the grahpics card is screwing up in some way, but if it only started happening after you updated Windows, you should probably do a clean reinstall and see what happens.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/645771-computer-problem/#findComment-8312349
Reinstalling windows had no effect still crashes in game. You have any ideas what it can be?
https://linustechtips.com/topic/645771-computer-problem/#findComment-8316347
Maybe.
Can you post a list of your hardware?
Also, try stress testing your Graphics Card with Unigine Heaven, 3DMark Frestrike and FurMark (the free versions) for a few hours to see if you euncounter any graphical glitches or crashes.
https://linustechtips.com/topic/645771-computer-problem/#findComment-8317361
19 hours ago, Litargirio said:
Maybe.
Motherboard:Asus z87 Deluxe
Cpu: I7 4770k
Ram 16gb
Gpu 2x280x in sli
Ssds: 5x 258 gb samsung
I've tried running 3dmark but it crashes like in any other game
https://linustechtips.com/topic/645771-computer-problem/#findComment-8321546
So it seems like there is a problem with one of your graphics cards.
To see if this is the case, leave only the first graphics card in the motherboard (remove the second one), and run the benchmark again. Then, change them around; remove the first one and insert the second one, and rerun the benchmark.
Make sure you put both graphics cards in the same slot, both times, not in differents slots.
Does it crash with either graphics card in? Only with the first graphics card but not the second? The other way around?
https://linustechtips.com/topic/645771-computer-problem/#findComment-8326511
I will try that, i'll be back when i tried that
https://linustechtips.com/topic/645771-computer-problem/#findComment-8327503
