I have an Intel Core i7 6700k, not sure if I'm going to overclock or not, but I want to be prepared. What's the best CPU Air Cooler for it? Looking for good temps and according to my case, can only fit 156mm height CPU Coolers, but I've seen 1 or 2 people use 160mm CPU Coolers, so idk how they did that. My case is the InWin 805. I just want safe temps when idle (under 30C)/load(under 60C).
https://linustechtips.com/topic/645463-best-cpu-air-cooler/
Idle temps don't really matter and you're fine up to 80-90c at load.
Not sure where you got your 'safe temps' from but they're very low.
What cooler are you currently using? Why get a new cooler?
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308769
This is my first build. That's what my friend said are "good" temps
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308777
Those would be very good temps but it's much lower than necessary. So you don't have a cooler yet?
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308781
No I don't that's what I need advice on. I wanted to get the NZXT x61, but I decided that I wanted air for the reliability and the longevity.
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308788
That's a lot more expensive than necessary if you aren't planning to push the oc as far as possible.
If you would like a cooler recommendation, it would help to know where you're shopping/located.
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308801
Thanks for the help btw, appreciate it. I am in the US. So anywhere really. Newegg, Amazon probably.
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308811
5 minutes ago, Tweed said:
InWin 805
i like some of teh cooler master heat sinks like the 212 evo and some others. would probaly recomend looking into one of those for air cooling
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8308883
An Aidos Black would work: https://www.amazon.com/dp/B00KPUHQ84/?tag=pcpapi-20
If you want to get a beefier cooler for higher oc's while keeping noise down, the FUMA is another option: http://pcpartpicker.com/product/dVwqqs/scythe-cpu-cooler-scfm1000
My problem is, is that my case says the CPU cooler clearance is 156mm, but I've seen people use a Noctua NH-D14 which is a 160mm CPU cooler. So idk what to do.
It seems like they're understating the clearance just in case.
1 hour ago, Tweed said:
I was considering the Phanteks PH-TC12DX (If I can even fit it) or the PH-TC14S
They probably fit but no guarantees.
https://linustechtips.com/topic/645463-best-cpu-air-cooler/#findComment-8309280
