Hello!
I have made a list of what I would like my second build to look like.  Here it is.
CPU: Intel Core i7-6700K
Mobo: Gigabyte Z170X Gaming 7
CPU Cooler: Corsair H105
RAM: Corsair Vengeance LPX 16GB DDR4-2666
SSD: Samsung 850-EVO 250GB
HDD: Toshiba 2TB
GPU: EVGA GeForce GTX 970 FTW
Case: Fractal Design R5
Power Supply: Corsair RM650x
There are a few things that I would like a response to.
First of all, I would like to know what you think of the GPU and the CPU Cooler.  If you have other recommendations, please give them  Secondly, I would like to know when I should do the upgrade. If your response is one year, then should I possibly get a 980 or 980Ti since their prices will go down?   And finally, tell me (and/or give me the PCPartPicker link) what you think would make a great build around this budget.  My only requirement is that it has the 6700K because I really don't want to get another CPU.
PCPartPicker link: http://pcpartpicker.com/list/wLjXbj
Thanks!
https://linustechtips.com/topic/645032-second-build-help/
I'd go for a 1060, it's about the same price as a 970 and faster.
Other than that it seems like a solid build.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/645032-second-build-help/#findComment-8304058
