Best 'entry level' 144hz screen?
1 hour ago, keNNySOC said:
What resolution do you want 1080p 144Hz monitors are much cheaper than 144Hz 1440p monitors
1080P is fine.
Would G Sync make any difference if you can push over 144fps anyway? The type of games I play 144 should be no issue.
13 minutes ago, Contentin said:
1080P is fine.
Yes it would make a difference,but G-Sync monitors are a shit tone expensive just by themselves i recommend this one if you have the cash http://pcpartpicker.com/product/DbvZxr/acer-monitor-umfb0aaa01
