Okay.
Lately ive been thinking about going ahead and building a new pc and though the linus forums could answer my prayers. Currently i use an older imac (3-4 years) and it dosent have the power im looking for. As well as power the osx operating system is limiting to the gaming i wish to do.
     I have a budget of 1-1.5k and can flex a little if its for an upgraded part. I will most likely stick with one monitor but the option to run a second would be nice. I have a mice but would need a keyboard and prefered new mouse pad.
     This computer would be used for gaming and school. I would like it to benchmark pretty well/be able to play games at a good framerate.
     I have little to no knowledge of building a pc and am calling to the forums for help.
Thanks for reading!
     ~Tate
https://linustechtips.com/topic/643113-build-help/
6 minutes ago, T.w² | Tate .cL said:
Okay.
Thanks for reading!
     ~Tate
give me five and ill create a spec for you what games are you looking to play?
https://linustechtips.com/topic/643113-build-help/#findComment-8283745
9 minutes ago, T.w² | Tate .cL said:
Okay.
Thanks for reading!
     ~Tate
use this build you can make it cheaper by swapping out the 1070 with a 1060
http://pcpartpicker.com/list/dDKkXH
https://linustechtips.com/topic/643113-build-help/#findComment-8283755
31 minutes ago, T.w² | Tate .cL said:
Okay.
Thanks for reading!
     ~Tate
$1000-$1500 could get you a very good gaming PC. Are you gaming at 1080p? 1440p? Also, what type of storage options are you looking for? Does school work require anything CPU intensive? I'm just throwing these questions out there.
@Majestic_Koala's build looks like a good build if you're wanting to play games at excellent settings. I'd check that one out. The aftermarket CPU cooler may be a little tricky to install at first and isn't technically required, but it's far less noisy and much better than the Intel stock cooler.
Also, if you're wanting OS X, there's a little work involved in getting that on a non-Mac (known as a "hackintosh"); Apple doesn't support this in any way.
https://linustechtips.com/topic/643113-build-help/#findComment-8283759
what OS do you want. Windows is easiest but I can grab a build designed to run OS X for my friend
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/643113-build-help/#findComment-8283768
http://pcpartpicker.com/list/bz9y4C that is a great build for OS X. the OS is hard to install but this PC should work great but no 1000's cards as support is now out for 900 cards
https://linustechtips.com/topic/643113-build-help/#findComment-8283772
why i7? for games is useless spending 100 bucks more for hyperthreading
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/643113-build-help/#findComment-8283775
no some games love the extra threads
https://linustechtips.com/topic/643113-build-help/#findComment-8283779
for example? the most of the popular games doesnt
https://linustechtips.com/topic/643113-build-help/#findComment-8283784
cities skylines, most simulators and who know he may want to start making videos
https://linustechtips.com/topic/643113-build-help/#findComment-8283794
28 minutes ago, T.w² | Tate .cL said:
Okay.
Thanks for reading!
     ~Tate
here's my full build for you
http://pcpartpicker.com/list/gpMmkT
https://linustechtips.com/topic/643113-build-help/#findComment-8283803
Thanks all for the replies!
sorry if it was confusing but this build would be using windows, the comment on osx was that it dosent supports games i wish to play.
For storage im not picky, 500gb-1tb would be well enough and the type of storage i have no preference.
https://linustechtips.com/topic/643113-build-help/#findComment-8283828
