Hello there!
I am making a black n white build called the black snake.
I want to put some led strips in there too (white) for some extra smexyness
I saw a vid on yt off red memory stick red led. Than i thought "are there cheap 2x8 black memory sticks with white led"?
I searched it and i saw corsair sticks but they are a bit expensive so i am asking you guys, are there cheaper white led sticks 2x8
thankyou!
https://pcpartpicker.com/user/Wolfiowww/saved/Yqrypg
My main rig  Shardsedge
 ☟ INFO & SPECS
  • Information:
This build is made for video editing, Gaming and livestreaming.
probably 65% of this build has been bought used.
  • Specifications:
CPU  AMD Ryzen 7 1700
GPU  Sapphire RX 580 PULSE 4GB
SSD ✦ Toshiba TR200 240GB
HDD ✦ WD Black 160GB 2.5" + WD BLUE 1TB
PSU ✦ Corsair RM750X
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 3000Mhz
CASE ✦ Corsair Crystal 460X
MOBO MSI X370 SLI Plus
My old pc build  Smoke
 ☟ INFO & SPECS
  • Information:
This build was made for gaming especially, it was my second build.
i had some struggles livestreaming on it because the CPU just wasn't good enough for that.
(I do not have this build anymore)
  • Specifications:
CPU ✦ Intel i5 6500
GPU  Sapphire NITRO+ Radeon RX 470 4G D5
SSD ✦ Kingston SSDNow v300 120GB
HDD ✦ WD Blue 1TB
PSU ✦ Corsair CX450M
RAM ✦ Corsair Vengeance LPX 2x4 (8GB) 2400Mhz
CASE ✦ Sharkoon S25-V
MOBO ✦ MSI H110M ECO
https://linustechtips.com/topic/641734-white-led-memory-sticks-please-read/
11 minutes ago, Wolfiowww said:
Hello there!
thankyou!
DDR4 or DDR3?
Just now, Stylized_Violence said:
DDR4 or DDR3?
uhhh how do i know that wich ddr i need? xdd
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
What kind of motherboard are you getting?
MSI B150M MORTAR Micro ATX LGA1151 Motherboard
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
The thing with leds on ram is that it's not worth it, you're better off spending that cash on more led strips, and get some non-led dimms that fit your build.
A lot of the black & white people like to color-match the dimms to the ram slots on the mobo.
well i like led memory sticks.
 ☟ INFO & SPECS
  • Information:
  • Specifications:
 ☟ INFO & SPECS
  • Information:
  • Specifications:
CPU ✦ Intel i5 6500
HDD ✦ WD Blue 1TB
Geil makes some white LED 16GB kits.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
3 minutes ago, Wolfiowww said:
If you want them built in, then the Vengeance LEDs from Corsair are probably going to be your best bet. You'll need DDR4-2133MHz RAM by the way. There are some that are just plain white sticks, like some from Crucial, but it seems Corsair will be your best bet. I know you said they were a bit on the expensive side, but for one Corsair makes solid memory so you'll pay more anyway, but second LEDs are an added cost so they are going to be a bit more than other sticks. Sometimes you gotta pay for the aesthetics you want.
As do I, so I did spend more on my RAM.
