well, what kind of advice are you looking for? you seem to have made up your mind already.
https://linustechtips.com/topic/641644-help-me/#findComment-8269025
I need some advice from you?
what do you say about this company Alienware!
do you suggest me to another brand.
just like this.
can I trust this company.
is the material that the laptop is made is good (the quality).
https://linustechtips.com/topic/641644-help-me/#findComment-8269033
just like this.
i personally wouldn't go for a Alienware laptop, solely because they have a tendency to be overpriced.(in my opinion!) If they are available in your country, i would look into some other brands, like MSI, or ASUS.
If you do go for the Alienware laptop though, it is a trusted brand (Alienware=DELL)
https://linustechtips.com/topic/641644-help-me/#findComment-8269041
thanks.
but they are all same price.
MSI is more pricey and ASUS same like Alienware.
what do you say?
thanks xD
https://linustechtips.com/topic/641644-help-me/#findComment-8269050
thanks.
what do you say?
thanks xD
what are the specs on the Alienware and on the ASUS laptops you're looking at? Get the one that has the best specs!
https://linustechtips.com/topic/641644-help-me/#findComment-8269052
I want 980M.
Do you think that there will be 1080M !!!
give me your opinion.
http://www.dell.com/us/p/alienware-15-r2/pd?oc=dkcwf04s&model_id=alienware-15-r2
what do you say about this?
Thank you.
https://linustechtips.com/topic/641644-help-me/#findComment-8269059
Just now, SDJlegion said:
I've never had an alienware laptop but I had one of their desktops and it was awful.. kept breaking over and over, I got completely ripped off too. Make sure you know you are getting a good deal! I would go with msi or razer for laptops.
first thanks,
can you give me the model from Razer or MSI.
it will be helpful.
you said Awful now I am thinking about what to do next.
thanks.
https://linustechtips.com/topic/641644-help-me/#findComment-8269068
first thanks,
it will be helpful.
thanks.
As for MSI I don't have any specific model, but for razer the Razer Blade is a very good laptop (watch what linus has to say on it!), but it is very expensive.
Remember my experience could have just been a one off, and it wasn't a laptop.
https://linustechtips.com/topic/641644-help-me/#findComment-8269080
yeah I saw the video.
I like it.
but I am confused which one Alienware or Razer or Msi.
https://linustechtips.com/topic/641644-help-me/#findComment-8269085
3 minutes ago, SDJlegion said:
I think if you can afford it razer is the best gaming laptop, but of course it is your choice.
thanks,
but you know the problem is that razer blade is expensive for the spec they give only 970M 3 gb but,
on the other hand Alienware same price maybe 980M 8 gb.
that is the problem.
https://linustechtips.com/topic/641644-help-me/#findComment-8269108
25 minutes ago, Anonymous Helper said:
I want 980M.
Thank you.
I have an Alienware 14, it was not a bad machine. Rather sturdy in terms of the structure, cooling is adequate enough (it gets loud sometimes but the 14 only has 1 fan so...). What I don't like about it is the thickness.
What country are you from and what is your budget?
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/641644-help-me/#findComment-8269130
I am from UAE and I have 2500$.
thanks for helping.
https://linustechtips.com/topic/641644-help-me/#findComment-8269134
thanks for helping.
https://www.mythlogic.com/2015_Models/dia1615s.php
I would recommend this. Thinner, but still efficient in cooling. But you may want to wait a little, as the newer models with the Pascal refresh are coming out really soon (though I don't know how soon), then you can weigh your options available and see whether Maxwell or Pascal is more worth for your money.
You may find other laptop retailers with an identical looking machine as they would have both used the Clevo P650Rx series of barebones.
EDIT:
Or this if you want another retailer. Different retailers have different levels of customisations.
http://www.eurocom.com/ec/configure(2,339,0)ec
http://www.sagernotebook.com/customize.php?productid=886
https://linustechtips.com/topic/641644-help-me/#findComment-8269160
EDIT:
Thank you very much.
https://linustechtips.com/topic/641644-help-me/#findComment-8269218
Pascal is currently available. Pick up something like a 1070 in 15inch from HIDEvolution, BGA or socketed up to you.
3 hours ago, JasonFromTPA said:
You can certainly trust Alienware, as it is Dell's gaming company.
This is firstly bullshit, secondly a poor generalization. Alienware is so far up it's on ass it hasn't even launched Pascal along with everyone. They've moved into BGA for enthusiast laptops. They've gone backwards since they locked their products down to 330w for the sake of doing. Secure flash incoming.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/641644-help-me/#findComment-8298237
